ctznarcane
Need advice please...
Objective:
- Rebuild a '12 JKU that will run 37s on full floats and be comfortable at highway speeds. I'm trying to avoid building something that will need to be trailered for 1500+ mile drives.
- Would really like to have some decent turn radius and not be too wide in wooded trails
- Jeep IS NOT a daily driver.
Optional: Keep the door open to someday run 40s
My initial idea:
Dynatrac Hardcore 60s in standard 68.5 width and 5.13 gearing
ATX Chamber II Beadlocks (4.06" BS)
37x*12.5r17 Coopers STT Pro (I run 37 Coopers ST Maxxs' now and love them)
*I figure the 12.5 may help prevent rubbing (?)
Evo Double D Long Arm (optional with coil overs)
PSC Hydro
*Basically, something 2016-era Rubicat-ish but without the d44 up front and the DTD setup
What I'm replacing/hoping to sell to partially fund:
- OEM Rubicon front axle (Trussed, gusseted, LCA skidded, with RCVs, lower shock relocation brackets, tube seals, Synergy tie rod and BJs, newer unit bearings, Clayton high steer)
I was thinking of selling the axle with all of that as a fully upgraded "ready to bolt-in" and starting fresh
- Teraflex CRD 60 semi float rear axle with ARB (they now offer a full float conversion but it will still only be 67" wide).
- Clayton Premium 3.5" mid arm lift with new coil springs and rebuilt clevs and Johnnies
- Woods 1310 front and rear shafts
- The Coopers I currently have on non-bead lock rims (13k on the tires)
Budget is $25k total, some of the funds will come from the sale of the old stuff.
See any issues with my 'plan'?
What would you do?
Objective:
My initial idea:
PSC Hydro
What would you do?
