Mike Pierson
If you have a 3.5” lift on a 4 door JLUR, did you adjust your castor from stock? If so, what did you set it to?
IIRC when I had 3.5” springs I just tried to match stock castor best I could.
Did not do anything, just set everything as per EVO instructions and it was and still is perfect after 70k miles
I always try to keep my caster set at about stock when running factory axles. On my 1-tons with locking hubs, I'll go up to about 5-6° but no more.
Ok, the consensus is stock… that’s good enough for me. Rencho had me set it to 6 for spring issues but it feels terrible. Setting it back to stock and using Eddie’s trick with the upper isolaters. Thanks guys.Mike, I’ll verify mine today, but should be around stock, but where I have it set with 3.5 springs and Overland brackets it feel’s like stock.
What is stock castorOk, the consensus is stock… that’s good enough for me. Rencho had me set it to 6 for spring issues but it feels terrible. Setting it back to stock and using Eddie’s trick with the upper isolaters. Thanks guys.
Right around +5°. So if the pinion is at 0°, you are at +6° castor.What is stock castor
