lockers ...
Franck
hi !
i was thinking of having lockers on our 2011 sahara. What this would imply in term of mods (and money of course)? ... (I now realize that i should have bought a Rubicon instead ... but ...)
What parts would you recommend ?
thanks in advance !
if you think you might install larger tires in the future, like 35's, i might recommend that you hold off on lockers until you do that so that you can regear at the same time. lockers will replace your carriers and really, one of the biggest cost to installing lockers is the labor. needless to say, you might as well do that at the same time. down here in southern california, you can get gears installed for about $1000 USD at off road evolution. i would highly recommend something like an ARB locker as they are selectable and each of those cost about $800. you will need to get a compressor to run them and that will set you back about $200.
Thanks a lot Eddie, and yes : 35' are planned for this spring so ... i will check with my local dealer for that :)
