JLU TPMS when airing down
Mat Noble
My daughter has a 2020 JLU that the TPMS system low pressure alert illuminates in the dash and audio alert comes on strong when tires are deflated.
Is there a way to turn this notification off when offroading? Or do we need to purchase a programmer?
Unfortunately, even with something like a Tazer, the lowest you can set it is 25 psi. Anything below that and you will still get the TPMS warning on your EVIC. Sucks but what can you do.
Upvote 0
Weird… mine comes up with the warning once after I’ve aired down, but then I switch the view to off-road or something else and it stays that way until I cycle the jeep.
Upvote 0
Don't know if it can be done with a Tazer or another OBD programmer on the JL but I actually completely turned off the system on my JK and removed the TPMS sensors and changed to standard valve stems when I swapped wheels.
I monitor my tire pressure the old school way with an air pressure guage and can run whatever PSI I want with no warning light at all, but if you like the convenience of what you can see on the EVIC your best bet is probably what Eddie said. 👍
Upvote 0
On my 19 after I air down it'll give me a few chimes and the light, but after driving for a little bit it just gives me the light and stops yelling at me. It does it again if I stop and restart, but doesn't last long.
Upvote 0
This is correct. You can change the EVIC screen but if you turn the engine off and turn it back on again, the TPMS warning will come up again.
Upvote 0
Yes, this is always an option too. (y)
Upvote 0
Thank you for your feedback
Upvote 0
Jscan. With a minimal investment, around $50, you can turn the system off and on with your phone. You also have the option to change the threshold at which the systems alert is activated.
Upvote 0
