piginajeep
The Original Smartass
This date in 1953 the first CJ3-B went into introduced
•Engine: "Hurricane" F-head, 134 cu.in. (2.2 liter), 4 cylinders
•Cooling system capacity 11 qt. (10.4 ltr.) (12 qt. with heater)
•Electricity: Battery 50 Amp. Hour 12 volt, Generator 35 Amp.
•Front axle: Dana/Spicer 25, 27 or 27A, Full-floating hypoid, Ratio: 4.27:1 (5.38:1 optional)
•Rear axle: Dana/Spicer 44, Semi-floating hypoid, Ratio: 4.27:1 (5.38:1 optional)
•Brakes: Hydraulic, 9 in. drum diameter x 1.75 in., 117.8 sq. in. braking area.
•Clutch: 8.5 in. Auborn or Rockford single dry plate with torsional damping, 72 sq. in. area. (Optional Auborn single dry plate, 9.25 in. dia. )
•Transfer case: Spicer 18, 2 speeds, 1.00:1 and 2.46:1 (26 tooth input gear and 1-1/8 in. intermediate shaft up to serial number 54-12506; 29 tooth input gear and 1-1/4 in. intermediate shaft after serial number 54-12506)
•Transmission: Warner T-90 3-speed syncromesh, Ratios: 1st-3.339:1 (or 2.798:1), 2nd-1.551:1, 3rd- 1.00:1, Reverse-3.798:1
1986-
The Last CJ7 rolled off the assembly line in Toledo
sources- CJ3B page and wikipedia
Specs-The Willys CJ-3B replaced the CJ-3A in 1953, the same year Willys was sold to Kaiser. Kaiser removed "Overland" from the subcompany name. CJ-3B introduced a higher grille and hood to clear the new Willys Hurricane engine. A four-speed manual transmission became optional in 1963, at the cost of $194.[4] The turning radius was 17 ft. 6 inches.[11] The CJ-3B was produced until 1968 with a total of about 196,000 [12] produced, although the design was licensed to a number of international manufacturers, including Mitsubishi of Japan and Mahindra of India. Mitsubishi's version was built from 1953 until 1998, while Mahindra continued to produce vehicles based on the Willys CJ-3B until October 1, 2010. The M606 was a militarized version of the Jeep CJ-3B.
1986-
