Going from TJ/LJ Long Arm Kit 6” to 4” .. possible?
Mexican_Guard
Is it possible to swap my 6” spring to 4” if I have this 6” kit installed? Would I have to swap more of the kit? IMG_1453.jpgIMG_1454.jpg
The trackbar bracket is usually shorter on the 4” kit. It’ll cause dump steer if it’s not changed out.
Shocks might be wrong height as well, may be a good time to switch to a better quality shock if they are. The picture you posted is a short arm kit not a long arm kit btw.
What’s your plans for your old springs [emoji848]
Ahh I didn’t even notice that, I just took it off the site real quick. My kit is a long arm though. The plan so far is new springs, shocks, and track bar. My current track bar is adjustable but may still be too long.
When I do change them out you’ll be the first to know if you’re wanting them.
I am about to pull the trigger on these. My track bar is 3”-6” so hopefully it’s work. If not it will be next on the list too.
Any opinions?
The shocks will be the same length, the only difference is that bracket.
Just don’t put it on and see how it steers.
