Differential gaskets
newbwarewb
Looking for advice on gaskets for the differentials both front and rear.
I have a 21' Rubicon. Not sure if gaskets are bad but do see a leak around them.
T.I.A.!
Your axles should have drain plugs but as mentioned, the factory gaskets are really nice. Otherwise, I personally like to use Permatex Right Stuff.
My Gladiator doesn't have the drain plug sadly, so I have to remove the cover to change.
It seems like a leak, but nothing is actually leaking. Just have a darker spot at the bottom
