This SKY HIGH, all white Jeep JK Wrangler with a unibrow at the 2017 SEMA show Gear Alloy display, got its nose bleed height from the all new Rebel Offroad semi-Double Throw Down system.  I say "semi" because it's only running bypass shocks up front and single coil overs in the rear. I should also note that the rears have almost zero pre-load set on them and have maybe 4" or so of up travel but the fronts have a crazy amount of pre-load and still has upwards of 8" of up travel or more. I'm not 100% sure what control arms it's running with it but so far as I can tell, it looks like it might be BDS.
A JK ain't badass if it ain't got a unibrow!
As you can see, this kit comes complete with steering geometry that'll REALLY make you feel like you're driving a crazy tall Jeep.
Apparently, the remote reservoir comes with a built in indicator that tells you when it's time to service it.
Being shown for the first time at the 2017 SEMA show is the all NEW brake line and speed sensor routing kit.
No need to worry about the sway bar links over extending when the coil overs don't have much down travel left in them.
In all fairness, I really do like the white and black KING coil overs - they look super sharp :thumb:
