:thinking: I never took my Brake Pads to bed before, but I will tonight. :cheesy: Sorry couldn't resist!:beer:
you will wake up with the Jeep itch in the morning:cheesy::cheesy:
Wayoflife,
Thanks for the write-up. I noticed you bought the pads from NAPA but I can't tell what type of pads, are they semi-metallic or ceramic? As I understand it, you get longer pad life with the ceramic pads however, at the expense of the rotors. What type of pads did you purchase? The stealership is recommending the Mopar Value-line semi-metallic, what do you think?
Russell
In my personal opinion, you never want to run ceramic pads on anything but a sports car, and even then, only if you plan on hitting the track (and if you don't mind ruining your wheels.)
nice write up!! maybe its a dumb question but on the retaining clip no need to put any grease? thanks
I use a little Anti Seize Grease on the anti rattle clips and the caliper pins. Also a good idea to use loctite on the caliper bolts.
