JeepJeep75
I think I paid around $10 for mine ordered straight from the dealer. I had to provide a part number to ease the puzzled/astonished/confused look I was given when I asked for the part.
			Well, I guess we are driving supply and demand!
It's worth $16!
Quick question just so its clear......
When you remove the 2 lower 15mm non adjustable screws from the bottom of the headlight bucket, do you put one back on the non replaced adjuster side or do you mount it with just the 2 adjusters?
The one additional adjustment screw replaces one factory 15 mm screw. Everything else will be as you found it during disassembly.
So when you put everything back together, do you tighten all three ring/adjuster screws all the way as the starting point?
I have TruckLites and I kinda eyeballed them in the daylight. You know how you can see that a headlight like this is pointed way off? I just tried to square them up. Then I did the standard aiming at night on the garage door. Hope that helps some.
Question on cutting the notch for a flat head, do you just notch the inside screw on each light or both? My lights are off to the left and I don't want to be blinding people. The notch will be the quickest way to address the issue.
Thanks guys. I will eventually get the replacement. I ended up notching both as I need to move the driver's side left and couldn't get the notched screws to tighten. It works for now next time i'm in that area i will replace them to make things easier in the future.
