Disciple Off Road
Yeah…..I’ll get right on that……I do hope you're planning on installing a full skid on that building before you hang up that new sign of yours![]()
Honestly, at first I thought he may have puked on the blackstone… I’m still not convinced he didn’t.Looks great Jeremy! But man I just knew this is what you guys chow down on at the shop.
Lol I was thinking the same thingHonestly, at first I thought he may have puked on the blackstone… I’m still not convinced he didn’t.![]()
See….i was gonna say it was awesome…..but his IG post changes everything. So I’ll just say, he did a good job cooking.Honestly, at first I thought he may have puked on the blackstone… I’m still not convinced he didn’t.![]()
Close enough? lol.
Most all clamps have the set screw that goes all the way through however, they used two different halves of clamps as the lower portion is actually a double sheer. It’s also the wrong size clamp for the tie rod which is why is lifted up by the through bolt.Close enough? lol.
Is the threaded hole for attaching the stabilizer to the clamp a thru hole? Did they use a longer bolt and drive it all the way down to the tie rod like a set screw?
Only ghetto-rig I could think of for this..
WTF - really?? Simply unbelievable...she payed for this install. This is just one of many issues we saw on the surface.
It did in fact technically mount the stabilizer, yes lol
But did it work?
Shit.It did in fact technically mount the stabilizer, yes lol
Here is also a look at the aluminum tie rod end opening up causing play…
BUT BUT BUT... everyone on social whoring swears this is the best shit since sliced breadHere is also a look at the aluminum tie rod end opening up causing play…
u-joint bad or is the movement because of the tie rod?It did in fact technically mount the stabilizer, yes lol
Just the movement from wheel turning but will check them since we will be pulling them to replace the inner seals.u-joint bad or is the movement because of the tie rod?
I ran it for a while to try it out and know a lot of people out there are and I’m sure it’s been fine for most. But this certainly shows one of the downsides to aluminum. Will also add we have seen this to the point of stress cracks on the outside at the joint along with full breaks. Big reason I chose to go with a chromoly steering this go around especially pushing 40’s. At least I can weld mine if it breaksBUT BUT BUT... everyone on social whoring swears this is the best shit since sliced bread![]()
But but but, chromoly is no better than OEM. At least, that's what I've been told on the internetI ran it for a while to try it out and know a lot of people out there are and I’m sure it’s been fine for most. But this certainly shows one of the downsides to aluminum. Will also add we have seen this to the point of stress cracks on the outside at the joint along with full breaks. Big reason I chose to go with a chromoly steering this go around especially pushing 40’s. At least I can weld mine if it breaks![]()
Looking great! Call me weird but I love the normal JK hood.Ok….i think it’s fully back together now. Fenders are back on and got a new batch of windshield banners.
Also had some of these made.
