About a year ago, I did a little overhaul on my 2012 JKU. New plugs, PCV valve, and valve cover gaskets, among other things. I followed all installation and torque specs to the "T" but recently noticed some oil seepage. It appears to be coming from my passenger side camshaft position sensor.
It was wicking oil up to the point that the wiring harness attached to it was wet and it was seeping down the side of the valve cover. To verify it wasn't the seal on the retaining bolt or valve cover seal (which was replaced), I cleaned it off a couple hundred miles ago. After checking it, it was moist with oil again.
It appears that the sensor must have an internal failure allowing oil to pull through the sensor, into the base, and into the female end, allowing oil into the male plug and up the wiring. This is the only explainable source of oil and I think it's definitely possible. Is this something anyone else has heard of or experienced? At this point, I'm probably going to just replace the sensor, even though it hasn't thrown a code for it yet.
Here's some pictures:
