SP9100
SalS
Good morning, new to the forum from So. Cal.
Received my Switch-Pro SP9100, as I was taking inventory of the contents there was no negative cable (all the videos I’ve seen connect a negative cable from the power mounting plate to the body) and the mounting plate bracket received is not curved like what I’ve seen on the videos, it’s flat and does not curve down between the battery and fender. Will it still work?
The flat plate is a universal plate. Assuming you have a JL or JT, you can still make it work or you will need to order a separate mounting plate made for them. As far as the ground cable goes, I would call Switch Pros as maybe it was just left out by mistake. They are in SoCal and should be able to help out quick.
FYI -Switch-Pros informed me that JK and JL installation kit is sold separately for $85.00 plus applicable tax and delivery method
You'll be glad you went with Switch Pros. It's a great system and their customer service is very helpful if you ever have any questions.
