Enforcer lift
DKronk42
So, my ultimate plan is bolt on coil overs but that is way way down the line. Until then i was planning on 3 inch enforcer. My question is if i get the 3 in for 35's, and decide at a later date that i want to go 37's what dies this entail?
You'll be fine you have a 2 door. You'll get 3.5" of lift. Might need to trim a bit. You also need rear upper adjustable control arms with the enforcer. Along with both driveshafts.
Yeah i was counting on those, i was just curious because my jeep build is going to be very slow due to budget constraints, and i dont plan on going over 35's but i know how i am... And i was wondering if it was better to just get the 3in for 37's just in case. Thanks for the info man
Look at Hinrich build. He has the 3" plush ride springs with 37's. He had about 3.5" just like overlander said
Sent from my iPhone
I guess my confusion stemmed from earlier today, i was on northridge and noticed a 3in for 35's and a 3in for 37's as well as a 4in for 35's and a 4in for 37's, so i was unsure if the two lifts had any different hardware other than maybe bumpstops.
