DirtHeadDavis
Good call Mike! I think the RS7MTs are gonna be my next shock as well ![Thumbs up (y) (y)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks, Presley, I think you’ll like them. I doubt they will hold up to the desert any better than the 9000s did but they’re only $90ish so that’s fine by me.Good call Mike! I think the RS7MTs are gonna be my next shock as well![]()
Lol been there done thatThanks, Presley, I think you’ll like them. I doubt they will hold up to the desert any better than the 9000s did but they’re only $90ish so that’s fine by me.
Also, if you miss getting the lower bolt through once you cut the strapping, it’s an absolute bitch to get them to compress at the same time trying to get the bolt in. I missed two and paid for it.![]()
I never try to get the bolt in first try. I just set the top cut the strap and guide it into the shock bracket mount. Then take a pry bar and lift it and the bolt goes right in. It’s way easier that way.Thanks, Presley, I think you’ll like them. I doubt they will hold up to the desert any better than the 9000s did but they’re only $90ish so that’s fine by me.
Good info, thanks. I won’t screw around next time, I’ll do this- sounds way easier for sure.I never try to get the bolt in first try. I just set the top cut the strap and guide it into the shock bracket mount. Then take a pry bar and lift it and the bolt goes right in. It’s way easier that way.
I mean, if you could compress them by hand they probably wouldn’t do much for a 6000 pound vehicle lolGood info, thanks. I won’t screw around next time, I’ll do this- sounds way easier for sure.I honestly had no idea they were under so much pressure.
If shock is already extended and you don't mind getting dirty, lay on your back and you can 'bench press' the shock up and it's not too bad. Easier than fighting it while crouching down. Overlander's method is even easier though.Good info, thanks. I won’t screw around next time, I’ll do this- sounds way easier for sure.I honestly had no idea they were under so much pressure.
Yeah, when I said I paid for it, it’s because I had to bench press it back up into the bracket. It sucked so bad.If shock is already extended and you don't mind getting dirty, lay on your back and you can 'bench press' the shock up and it's not too bad. Easier than fighting it while crouching down. Overlander's method is even easier though.
No pain no gain!Yeah, when I said I paid for it, it’s because I had to bench press it back up into the bracket. It sucked so bad.![]()
Stop being a little bitch.Yeah, when I said I paid for it, it’s because I had to bench press it back up into the bracket. It sucked so bad.![]()
Perhaps it helps to jack up the frame of the Jeep so the suspension is already close to fully extended? Or at least close to the shock's strapped length?Thanks, Presley, I think you’ll like them. I doubt they will hold up to the desert any better than the 9000s did but they’re only $90ish so that’s fine by me.
Lookin great! 37s or 38s?Got the new Ridge Grapplers installed. Pulled all the weights off the wheels from my STT Pros and went all the eat to 75 with nary a shimmy. I’m also impressed at how quiet and smooth they are.
I stayed with 37s for now. Need an EVO carrier and more cash. Perhaps next year.Lookin great! 37s or 38s?
Looks great! Now it's time to hit some dirt with themGot the new Ridge Grapplers installed. Pulled all the weights off the wheels from my STT Pros and went all the eat to 75 with nary a shimmy. I’m also impressed at how quiet and smooth they are.
Yes! And I’m so ready!Looks great! Now it's time to hit some dirt with them![]()
Thanks, Ben!Looks great man!
