Painting inner fenders
Clifford33
So iv been wanting to paint my inner wheel wells for a while now. I think it just looks really clean with them black. I have factory cut fenders and just want some advice on spraying my wheel wells.
The factory plastic or the tub? I just used black frame paint. It’s held up pretty well but now it’s under liners.
I used black undercoating paint on mine. It keeps it a little different from the armor, which is regular paint.
I used Raptor liner in the spray can for mine, it turned out good, at least I think so. Just be sure to take the time to prep the area correctly.
Sent from my SM-S506DL using WAYALIFE mobile app
I also used a rubberized undercoating. I roughed up the surface with 400 grit paper if I remember correctly. Then I wiped it all down with lacquer thinner. I don't remember if I primed it first or just sprayed it directly on. It's been that way for about 7 years and has held up really well.
I bought some automotive matte black to spray under there and was thinking of sanding it a little so the paint will stick.
I sprayed mine with a rubberized under coating. I went with the rubberized to help deaden road noise or rocks that hit inside.
IMG_6077.jpg before trim
IMG_6080.jpgafter trim
IMG_6079.jpgbefore trimIMG_6081.jpgafter trim
Trimmed and painted fender wells. A lot cleaner now.
