LED Halo head lights and LED turn signal issue?
13stocjohn
I’m trying to connect Raxiom LED halo headlights with Axial LED smoked turn signals. I’ve spliced the additional black and red wires from the headlights to the ground and daytime running light cables attached to the turn signal wiring, black to black and red to either green or brown via vampire clips.
The halos and signals both turn on when I turn just my dash lights and signals on and again, everything works when I turn on my additional headlights. The problem is when I turn my signal either left or right, nothing happens. The turn signals don’t signal.
What am I doing wrong and how can I fix this issue?
I don't have the same brand, but on mine there is an additional wire for the turn signal input. Yellow, I believe. Yours doesn't have this?
Yeah, there’s an additional wire but I was under the impression to use the middle wire of the three in both turn signal cables. Should try to connect the red wire to the third yellow wire and keep the ground connected?
I'm talking about the wires on the new headlight, not the Jeep's harness. On mine there is a red wire that taps into an ignition switched hot lead, a yellow wire to tap into the turn signal, and then the normal plug for the actual headlight connection.
Hmmm, they said they’d work for all jk model years. It came with limited instructions but I wouldn’t call the 4 pictures on a single page much instruction.. anyway, heres the link to the exact headlights.
https://www.extremeterrain.com/raxiom-headlights-w-led-halos-0718-jk.html
However, I did some digging. It “turns” out that the turn signals are a piece of junk. Other jk owners had the same problem I’m having it seems after reading the reviews
