A. Outlet of points to ponder.
1: Get a bigger trailer than you think you need. 20' minimum.
2: Get 5,000 lb axles. Better brakes. Higher weight capacity.
3: Get brakes on both axles. Safety first.
4: Consider a deck over. Wider axles & tires might require it.
Why are you concerned about your suspension cycling?Yes I agree that the d-ring shouldn't be the primary, but the one advantage to having it as secondary is it keeps your suspension from cycling while on the trailer, which could be several thousand miles.
What trailer did you ask about and what were the different quotes you received? Also be careful with a deck over as they sit quite a bit higher. Might look into something with drive over fenders that is 102" wide like a PJ B6.I just got back from 5 different dealers. Its amazing how differently some businesses price the same exact trailer. Anyways, thanks to everyone for helping a brother out with all your input. :thumb::thumb::thumb:
I'm really not that concerned, I'm not really panning on trailering my new rig, but my reasoning behind doing it that way is that keeping the straps at 45 degree angle is that it pulls the jeep down on the trailer. And with it not cycling seems to be a bonus, because if you are going to trailer your rig and you have 12,000$ worth of coil overs and bypass shocks it seems like it would save the oil and where and tear on other parts too. I am not an engineer and have no type of data, but in my dirt bike days a friend of mine used to sag the rear of his bike down so it would not cycle. He told me to grab my oil reservoir, that was not tied down and it was hot from going up and down and his of course was not hot at all. Just my 2 cents.
I agree with the above.
Get a big trailer. Get strong axles.
I like D-rings to the axles but do Y straps over the tires. I think D-rings are better because when you stop the rig doesn't 'roll' forward (an inch or two). Plus with the D-rings to the axles you still have the vehicles suspension to absorb some of the bumps.
I don't like the lasso either. But it's quick and easy for a short tow to the trailhead
That's crazy. Mine was just over 4 new with 5k axles in 15. What other upgrades are u getting?Congrats.
I've asked 4+ dealers for a quote on a PB B6 102"w x 22' and I'm getting quotes for $8-10k. Granted I have anywhere from $1000 to $1500 in upgrade but still seems a little pricey.
I don't believe I would want torsion axles on a car or truck hauling trailer.
Here's my reasons.
1) Because a typical spring suspension will equalize the cargo weight between the 2 axles. Torsion axles will not.
2) The vehicle you are hauling on the trailer will have its own suspension. Therefore the rougher ride of a leaf sprung suspension will not harm the cargo vehicle. Dexter Axle makes a cushioned equalizer that will smooth out the bumps a bit. It's greaseable, too. AND very heavy duty shackles.
I am dead set on torsion axles. They are the equivalent of having independent suspension and will provide a smoother ride than leaf springs will.
All tandem and tried axle spring trailers come with axle equalizers, the ones he is showing are simply nicer riding ones.First off you shouldn't need to add a kit like that in order to equalize the load over 2 or 3 axles. I am very familiar with towing and have towed mylitiple configurations. This car hauler will be on the smaller side of what I usually tow. Many people feel the need for kits like you posted for a variety of reasons like having a truck that is lifted and a trailer that doesn't sit level or people that don't properly distribute the weight of the cargo. Both those issues will be addressed including tongue weight. For those reasons and a few others that I will address I think torsion axles are the way to go for me. I do appreciate the input!
