2" Plush ride coils for us 2DR drivers
warnabrother
Any plans to make a full set i.e. front and rear of 2" plush coils..
I know lots of 2DR's don't want OR need the lift given on the 3" coils..
TIA
Welcome to wayalife.
The leveling kit is 2".
thanks.. been lurking here for 1.5 years...
yes, I understand the leveling kit is 2", however I am not interested in spacers for the rear ;)
so basically looking for the front springs out of the leveling kit with some 2" rear springs.. and to run these with 27/28" shocks appropriately bumped of course..
Wouldn't running 2" springs in the rear make your jeep nose dived again? You could throw some 59/60 springs from a 4 door in the rear and can give you a little bit of lift
With a 27ish" shock spring retainers and/or limit straps would be needed as any stock spring would be too short when free.
I think the desire for an EVO 2ish" rear coil is in hopes that it would have a longer free length. (But don't want to put words in the OP's mouth.)
Sounds like he wants to keep the factory rake. I know I don't mind it at all.
Aahh ok that makes sense
You may be right
yes.. that is exactly what I (we) want..
2" above stock, plush ride, long free length
the rake doesn't bother me and I imagine would help a little offroad with weight transfer
I just like not sagging while pulling a trailer and such. I hate it when the front is higher than the rear in any case.
I'm thinking about the 2" plush ride springs as well for my 2-dr. I'm currently running #59 rear springs. If the 2" plush rides lift the front around 2.5", then I'm considering 2" Teraflex coil spacers for the rear or possibly 1.5" rear spacers. My Jeep doesn't have as much rake as most, and I tow as well. If you really want to change rear springs, what about the 1" rear springs that Teraflex makes? You could even combine them with their 1/2" or 1" guide coil spacers. Also, RK makes springs that lift the rear of a 2-dr. about 2".
I'm also interested in these, I saw a four door get around 2" so hopefully a two door would get higher. Its a long shot but hopefully someone has experience with these springs or the leveling kit in general
Teraflex makes a 1.5" rear coil, too.
I saw on another forum, that EVO will sell the 2" springs from the kit, without the rear spacers, if you call them.
I called EVO. The 2" coils aren't in the vendors catalogs, but they are available. The part # to give a vendor is EVO1074. I have a 2 door & have ordered those & a set of Teraflex 1.5" rear coils & 1/2" front spacers, to hopefully get a true 2" lift, or there about.
Lol that is going to ride like complete shit! Good luck with that.
You should have stuck with the EVO kit.
