Hangemhigh1
Unable to push the axle shaft all the way back.
Reinstalling the stock axle shaft. The axle shaft will not go past half way on my Dana 44 axle. Where is the seal supposed to be located? From my understanding the seal should be toward the rear of the shaft at the pumpkin. Is this correct? I removed 2 plastic guides from the inside of the tube similar to the ones in your picture. Could there be more? I snapped a picture prior to going to work. Not sure what this ring is, could someone enlighten me please? I a bit frustrated that I can’t get the shaft in as easy as the ones depicted on all the videos I was glued to prior to taking on this task. Thank you in advance for your response.
![38EA0D4F-FA73-4F78-A0E4-4D2A2166273D.jpg 38EA0D4F-FA73-4F78-A0E4-4D2A2166273D.jpg](https://www.wayalife.com/data/attachments/278/278679-7ccbd8bb98015fc381430a270596367f.jpg)
