VIDEO : JL JOURNAL - Help Your JL Wrangler Breathe Better Again
Changing out your air filter and on a regular basis is one of the best things you can do to help keep your Jeep JL Wrangler breathing in clean fresh air. Of course, it'll also go a long way to help give it better fuel economy, reduce emissions, improve acceleration and of course, prolonging the life of your engine. Fortunately, this is something that anyone can do, in just a few minutes and this short video, will show you how.
What You Will Need
• Mopar Air Filter - Part# 68257030AA
• Philips Screw Driver
• 8mm Socket
• Ratchet
• Long Ratchet Extension
I hope that you find our quick tip on how why you should change out your Jeep JL Wrangler's air filter and how to do it to be helpful. Please let me know if you have any questions. :cool:
Looks simple enough. No more clips and the new filter looks better than the one in my 2012 JK. Maybe motor replacements drove them to change and use a better design...:crazyeyes:. Thanks for sharing. How many miles were on your filter and how often do you typically change them?
Oh yeah, the JL filter is WAY NICER than what the JK had. There are way more pleats and the filter element seems to do a much better job of holding back dirt. I'm pretty pleased with it. I had about 11,000 miles on this one but had been meaning to replace it about 3,000 miles ago - just been way too busy. As far as how often I change mine goes, it really depends on the kind of conditions I've been in. Fortunately, Cindy and I are typically leading packs and so we see a lot less dust and under those situations, maybe once every 15,000. Recently, we've been in heavy dust conditions either helping at races or following a friend on a trip and so I really wanted to get this done a lot sooner.
Awesome video! Is there a reason you do not use a reusable filter like a k&n?
Reusable high flow filters are great on cars but allow way too much dirt to pass into the engine. I would NOT recommend one if you spend a lot of time in the dust like we do.
Oh I had no idea about that! Good to know [emoji106]
We had a 2012 RAM 2500 Diesel here at work and someone put a FRAM filter in it and it actually was getting sucked into the motor. I did not know and when I dropped it off at the dealer for a regeneration programming fix the service tech pulled it out and showed me. It was crazy just how much air those motors move. She then informed me that using any other filters (fuel, oil, air) besides Mopar would void the warranty should the motor fail. That would be about a 25K repair bill. Have been using Mopar filters in my Jeep ever since.
Dealerships have been known to void warranties for using them. Some have shown to let more dirt and debris through than the OEM filters.
Yup. This and I have personally seen people have their engines ruined from using them - even a dealer installed Mopar one. They are nothing but bad news on a Jeep.
Yeah makes sense. I typically change mine at every other oil change (I change my oil every 4k because of time not mileage) or after a dusty trip or two. Kind of like the Whiskey Wanderlust...haha
I should note that on Moby, we still have a high flow filter being that we can't run a factory filter. For him, I clean out his filter every other oil change under normal conditions. I clean it every oil change if we're in the dust a lot. Even then, I find some dust in the air tube - I hate it.
Looks like I’ll be getting a mopar filter soon [emoji51] thanks for the heads up!
VIDEO : JL JOURNAL - Help Your JL Wrangler Breath Better Again
Eddie have you tried running an Outerwear over Moby’s filter they help quite lot with the fine dust. I agree with you on running a OEM filter.
I love the intro [emoji7][emoji7][emoji7][emoji7][emoji7]super awesome [emoji41]. Great write up and I do see that in the near future [emoji23][emoji23][emoji23][emoji23]IMG_0065.jpg
Oh yeah, we've always run a filter sock and for a time, a foam pre-filter as well. I've since moved away from an oil filter and have been running a dry flow and that seemed to help out.
