Rebuild Ball Joint?
Mtb275
Recently I purchased a PR44 front. During inspection, I found the rubber on the lower driver side Ball Joint pushed out.
What is the solution for this? A rebuild kit? New Ball joint? Not worry about it?
Overall photo
Front side of rubber on Ball joint looks good.
Back side of rubber pushed out.
Overall photo
As long as there is no grease weeping out of the boot, they are ok, otherwise you will need to contact us at 714-421-4314 and get replacement seals. Also, on the bottom ball joint the rubber seal protrudes from the housing, whereas the top one does not.
Thanks for the reply.
Grease comes out like crazy. I'll be calling tomorrow.
