How long should my sway bar links be?
I have a stock JKU (sport) and I need new sway bar links. I’d like to get disconnects but there is little information on how long they should be. The stock unit was tiny — about 4-5” tops.
But I see you can but very long or even adjustable replacements.
I’m looking for speed — we hit the trail with three kids and sway bar D/C takes forever! I don’t really care about looks, I’m happy with simple black steel.
Any advice for a newbie?
thanks!
Did you test the disconnect by hand on the bench or on your Jeep to see if it's working properly?
Yeah for sure. Both before I installed the bar and since. I’m sure that when it’s engaged the force I apply with my hand is substantially less than the jeep rolling over even a small curve in the road. I suspect it’s not fully engaging too — but I don’t know how it would sound if it were broken.
Upvote 0
Not necessarily. If what you're hearing is a loud clunking or snapping, it could be not engaging. If what you're hearing is just a clicking, I would double check your link connection points as they might be just ever so loose enough to allow for movement. This is NOT uncommon.
Upvote 0
I pulled off the knob and reinstalled the actuator for a week in the sand dunes. Bar didn’t click at all and that confirms where the sound was coming from.
I emailed Evo and they came back with a rather short but interesting reply, which is that my particular bar might just need less pressure to work properly and their advice is to cut a loop at a time off the spring until it works correctly!
I’ll have to remove the sway bar to make that kind of process work, I could never get it to pop reliably when driving.
Anyway thanks for the advice!
Upvote 0
