TeamFaust
Okay, so this is most likely just me ranting and venting to a group that should understand the frustration.
I've been wanting to install a transmission cooler for a while and finally got around to getting all the parts needed. It's a pretty straight forward install...remove the grille, place some brackets, install the cooler, tie in the transmission oil line...probably less than an hour, no big deal right?
So last night I go to get started and pull the six upper body clips out around the top of the grille, disconnect the turn signals and start to pull the grille forward to pop the lower grille body clips and there it is...the back of the winch and its associated wire connections are so close to the front of the grille that it can't move forward enough to pull the body clips out of their holes...AAARRRGGHHH!!!!!! :shock: Really???? :thinking:
So after trying to prod, pull and coax for 20 minutes (this thing typically pops off in about 30 seconds start to finish), I think well now what? Looks like I'm going to have to somehow remove the winch to get the darn grille out...oh but wait the power cabling for the winch was just barely long enough to reach the battery in the first place and I really don't want to have to un-snake it and then redo if at all possible. Okay so maybe I can just loosen the winch mount bolts underneath the plate...well the back two are fairly accessible the front two...dang they are deep up in the front of the RR XHD bumper...this is going to be a real knuckle buster at best. Okay now it's dark, getting late and I do have to drive this thing to work in the morning...top grille clips back in, turn signals reconnected, hood closed. Guess we'll pick it up tomorrow afternoon so that if I have to take the whole front end apart at least I can let it sit until finished.
Nothing like a quick 45min accessory install that turns out to be so quick and easy -- although I am discovering most turn out this way :yup:...will be picking this back up as a weekend project. :crazyeyes:
Oh and BTW if anyone would like to offer any empathy, support, input, or "why didn't you do this dummy" advice/commentary have at it :thumb:
Here are a few pics so you can take look for yourself:
