Will it fit?!: 13.5" Wide Tires on Stock Wheels with 1.5" Spacers
I've got a 2013 JKU with a 3" lift running the stock wheels with 1.5" spacers. I'll be ready for new tires soon and have been debating betweiin 35's or 37's but assumed I would be sticking with a 12.5" wide tire. Just saw some 37" toyos pop up on craigslist but they are 13.5" wide. I'm assuming they are going to rub. Can anyone confirm?
Thanks!
Thanks!
They will rub. Sway bar, control arms. Maybe more. Im running 12.50 on my factory rims with 1.5" spacers and they rubbed. Had to adjust my steering stops a bit. I may be wrong without double checking the numbers but, with 1.5" on stock wheels, you still are left with 4.75" of back spacing. You need to bee more in the 4"-4.25" neighborhood i would think to be safe
That's what I figured. Darn.
Thanks for the response!
What others here have said. If you really want to run 13.50 wide tires, you really should consider getting wider wheels and ones that have closer to 3.5" of back spacing.
We are running 35"x12.5" NTG on stock wheels with 1.5" spacers and a 3" lift (net 3.5") and they don't rub. Biggest issue was getting them installed. As the stock wheels are 1/2" narrower than the tire spec, no one wanted to install them.
My wheels have 4 inches of backspacing with 35 12.50s and rub if you are articulated and turn sharp. So 13.50 on your wheels will rub. That is also a very narrow wheel for 13.50s I think stock is only 7 or 7.5 inches wide.
Where did you get them installed? Are you concerned about them popping off the bead at all, or is it just a concern running at low pressure. I want to get 35 x 12.50 on my stock wheels as well but Tire Rack won't do it.
I have the same as Rc. Here's a screenshot of a video. Check the driver rear tire. Didn't lose the bead. Not saying it can't happen, but it will hold better than you think.
ImageUploadedByWAYALIFE1437848631.319429.jpg.
Edit: that was at 8 or 9 psi.
Sorry to kind of steal the thread a bit but thanks for the replies guys. I really like my stock rims so I guess I'll just buy the tires when it's time and dig until I find someone to mount them. My 33" BFG AT's have about 34k miles on them and look like they could go that much more yet. Definitely sticking with them when going to 35's.
Big chain tire shops usually won't mount tires not approved for the rim width. I just had my mounted and balanced at a local off-road/4x4 shop. It actually came out cheaper than what other tire shops wanted to mount and balance.
Thanks for all the responses!
A 13.5" wide tire will be way to wide for the stock wheel as well.
I realized that after I posted as well.
I considered making the case to get new wheels, but I just don't think it's in the budget. For now, I'm just going to have to plan on running a 12.50 tire.
Duly noted. Thanks!
Hey all, I know this is an old thread, but didn't want to start a new one. Does any one know if a 315/70/17 tire will fit on the stock 17" Rubicon rims?
