This question comes up a lot, so I thought I'd start a thread that may hopefully help out. A Johnny Joint is made by Currie Enterprises. They either come as a fixed housing Weld on style like on an upper axle mount or they come as the type with the threaded section for use with an adjustable arm. The Johnny joint is a very large, tight joint, but the ball assembly inside allows smooth pivoting and less binding as the axle moves. They bind less than a polyurethane bushing are are affordable to rebuild. I'm not an expert, so if anyone has anything else to add, please do.
Here's some pics from Ddays' build thread comparing them to other types of arm ends. The larger gold-colored ones in the pictures are the Currie Johnny Joints:
Here's a Johnny Joint's internals. Basically, the order of parts that goes in the metal housing is WASHER, BUSHING, BALL ASSY, BUSHING, WASHER, SNAP RING. You can see that the housing has a snap ring groove and a hole for a grease zerk.
