Welding C gussets
JK12
So i get my EVO C gussets this Wednesday hopefully and i was wondering what settings you guys used for welding them?The welder i have access to is a Miller matic 252 i believe. Also i got some pro steer ball joints. Should i weld the gussets with the old ones in and then replace with the Dynatrac pro steers?
ya that would probably be a wise decision as to not worry about cooking the ball joints. then you can replace the oem ones with your new prosteer joints and be happy happy happy...
andrew -
Actually pull out the old ones, weld in the gussets, then install the new Dynatracs.
I know they work together. I just wanted to know how to process would go. Did anyone weld their own gussets in?
I did my own set but used teraflex guessets instead...also left the ball joints in place and just took my time, as for settings I cant help out since every welder will be different.
I removed the old ball joints and put the new ones in the freezer. Then I welded the gussets on and got the C really hot. The frozen ball joints dropped into the hot C pretty easy.
