Long story short got xd9000i and a disconnect lead. Installed the Power to the Alternator connector on the retarded 3 bank battery connection and the negative to well the negative post. Installed the winch connected the leads and nothing. I pulled the cover and made sure everything on the inside and outside of the winch was snug and no random kinks or cuts in the wiring. I also broke out my handy dandy volt meter and started testing connections. Through some trial and error I got the winch to spool in and out. But only if I added a separate ground wire and ran it to the brown wires on the noids. When I dont have the random wire on the noid, they don' make a sound. But as soon as i ground the brown wire (anyone of them) thing will spool and unspool.
Winch is 3 years old but was never installed or hooked up. That is what the PO said, and im inclined to believe him considering it looks brand new.
Things I have considered but not sure of but have checked and reattached about a dozen times so far.
-Negative lead from battery to disconnect
-Disconnect to Winch Motor
-Winch motor ground to controller port
-Have a Harbor Freight wireless control- possible issue with ground?
-The internal motor ground? or am I making stuff up?
Things I know
-Damn thing works ( go's in and out )
-Im not a electrician
-Im tired and I'm cold
The brown wires seemed to be all jumping off one another until the last one which had a lead that goes into the plugin.
Anyone of those brown wires gets hit with a ground wire the winch will respond to commands.
PLEASE HELP!!!
Things I know
PLEASE HELP!!!
