Turn signal no flash
Jeep066
My driver side parking light will turn on but will not flash when the turn signal/hazard is engaged. The factory harness looks to be a bit corroded so i'm assuming that this is more than likely the cause of the issue.
Anyone know where i can find this connector and how hard it is to swap out?
Check your fuses first. It was either m17 or 18 on the 2012 for turn signals. Not sure on a 14 if the same.
