Tube leak
TxCoastie
Had some great times last weekend wheeling at Hidden Falls.
But now the jeep is leaking gear oil from both front tubes.
My axle is sleeved so I couldnt locate any OUTER tube seals to fit a dana 30.
Are new INNER tube seals my only options to keep from water getting into the diff?
Thanks!
Sent from my SM-G892U using WAYALIFE mobile app
I am sorry to say it but if you're tubes are leaking now, they're most likely bent. Inner seals are what you need but assuming your tubes are bent, it most likely will NOT stop the leaks.
