So after installing my new truck lites last week, I noticed the chrome trim ring that holds the lights in place with 4 screws allows the truck lites to move around and shake a bit. What have you guys done to stop the movement from happening?
Thanks,
Sean
Put some electrical tape around the black housing of the light. It will snug it up.
Sounds good, thought tape would do the trick. Thank you
I ran two loops around my passenger light and nothing around my drivers. Neither one moves.
Anybody else have an engine code come on after about 1-2 weeks for an issue with the low beam circuit? I installed the trucklites and anti flicker harness and the check engine light came on today with 4 codes, two of which were for the left and right low beam circuit. The other two were for an O2 sensor for the 2nd time, and a vacuum pump
Nope, although I don't have the anti flicker harness.
have been using trucklites for over 19000 miles and no codes thrown. No anti flicker harness but I am lucky and really have no flicker in either 2013 or 2014 wrangler. I did use dielectric grease tho not sure if makes a difference or not but makes me feel warm and fuzzy
It's a Jeep computer/sensor thing. The circuit is detecting a variant in the programmed voltage. It is more of a FYI code than a warning code and usually only shows up in company with another thrown code. Mine shows left and right high and low codes when some other code trips the check engine light, Otherwise, they don't come on by themselves. I think you will be OK. 18,000 miles on mine without any other problems.
I get the same codes.....my lights have been in for 2 years now and no problems with them. Been into the stealers with them fitted and not a word said (though that may be that they are crap)
So do you think the dealership will say anything about the headlights when I take it in for the other 2 codes?
Probably not. Took mine to the dealership for many oil changes and a couple of mechanical and electrical problems, but no mention of the lights causing any problems.
The codes are B1630 (right) and B162C (left) low beam control circuit high. I've had the headlights for a a couple weeks now so I'm not sure why the code would just be popping up...
Ever since I did away with the stock lights, that DTC code shows. Although they throw a code, they do not trigger a CEL. You have nothing to worry about those low circuit codes for the headlamps. I have an aftermarket DVD Nav and that also throws a code since it cant communicate with the factory radio.
