IgotaWoody39
For those of you contemplating replacing your leaking trans lines, be careful what you recieve from Rock Auto...I bought a full set of lines, supply & return from Rock Auto that were made by Dorman...Upon receiving them, I put them right on,,l went to work and back, 210 miles , had a leak again but not at the crimp between the black hose & aluminum sleeve...both flanges were leaking this time ..
this pic on top are the dorman lines, made in china, take a good look at the flanges that insert into the jumper block, their smaller in length..these must insert far enough to engage the inner rubber grommet inside the receiving flange...they appear much smaller in lenght & are distorted..
in this pic above where the lines are on my frt hood, these are new mopar lines from quadratec...check out the size of these flanges..they are the same size of my original lines I took out first that were leaking at black hose...just food for thought so nobody else has to spend the cashola on a subprime part...the mopar lines are not leaking...I also replaced the jumper block coming off the cooler,,,there was alot of crude inside the trans lines, and for a few bucks more, I thought it was a good idea..those spring c-clips are easily removed with small pics & upon re inserting your lines, You can put the c-clips on first then push the lines in,,,,it was alot easier than trying to put the clips on last...I couldnt find mopar clips but i did find GM trans line clips that are the same just a different color from Autozone...goodluck
