Tools for LCA adjustment
feederic
What tools (besides wrenches) are needed to adjust LCAs? I've been reading the JK alignment that adjusts UCAs and wonder if I could adjust LCAs while on a driveway. My only concern is how to get the LCA bolt back in once lengthened - could I just use a floor jack to reposition the axle to align back up with a longer control arm?
You'll need an angle finder to properly set the caster and pinion angle. You can use either a floor jack or ratchet straps to put the axle back in position for the bolts.
Sent from my ONEPLUS A3000 using WAYALIFE mobile app
Floor jack works well for twisting axle to where you want the arms. A hammer and prybar are all I use, especially a pointed one.
^^^^ this is the key, pointed pry bar. I don't jack the jeep up or anything. Just do one side at a time and use the pointed end of the bar to get the hole lined up. The smaller the adjustments you make, the easier it will be to get the bolt through.
I do have a few digital angle finders at my disposal. So a floor jack on the axle or tie rod plus a pry bar and I should be ok getting things to bolt up?
I appreciate the help - I'm mentally prepping for installing a lift.
You shouldn't need the jack but it'd be good to have. Great you have an angle finder but if you have problems, you can get an app for your smartphone as well. Besides that, wrenches, torque wrench and pry bar is it.
Yep. I prefer the ratchet straps personally because I find it easier to move the axle a bit more precisely.
Any of the above options work just fine. Be sure to have a torque wrench handy!
Floor jack and ratchet straps do work well. The pry bar with the tapered end is a good addition for any fine tuning. I have a long tapered punch I use to align the hole after it is close with the straps and jack.
