tonytony9
January 2014:
*Radio Installed
May 2014:
*Rugged Ridge 1.5inch Wheel Spacers Installed, Plasti Dipped Rims (Matte Black), Wayalife Windshield Decal Added (White), Soft Top Installed, MOPAR Hitch Installed, Jeep Logo Blacked Out
December 2014:
*Hankook Dynapro ATM 295/70/17 Tires, New Steering stabilizer, tie rod end/drag link, Serviced front differential (@114k)
January 2015:
*AntennaX (13-inch) installed, Firestick (red) installed with Rugged Ridge Mount & Spring, New Light Lens & New PIAA Lights & Blacked Out Light Trims
February 2015:
*Transmission serviced
March 2015:
*Rock Hard License Plate Relocation Bracket w/ ORO LED light/brake light, Shortened Firestick, Touched Up Plasti Dip
May 2015:
*JL Audio 500/1d Mono Amp, JL Audio 10W6v2-D4 Sub Woofer 10", JL Audio SGR-10W6v2/v3 Gasket/Grill, Sound Ordinance Ported Enclosure.
*Polk Audio db6501 6-1/2" Component System, Polk Audio db 651s 6-1/2" Slim 2-way Speakers, Pioneer GM-D8604 600W Class FD 4-Channel GM Digital Series Amplifier
June 2015: ~123,400
*New Back Brakes
August 2015:
*Removed "X" Stickers
November 2015: 124,000
*Rough Country 2.5inch Lift w/Stock Coils & Shocks
*Named the Rig "Sigmund"
Before:
During:
After:
December 2015: 124,000
*Brake lines replaced throughout entire truck
January 2016: ~124,500
*Limo tints added throughout truck (including hardtop windows)
June 2016: ~126,850
*Fixed cruise control lever & whining pulley
*Installed a Gibson Performance Dual Extreme Cat-Back Exhaust Black Ceramic & replaced entire exhaust pipe w/ a Walker OE Replacement Exhaust Pipe
*Fixed broken OE horn - replaced with Hella Twin Super Horns
June: 2016 ~127,050
*New Radiator installed (pipe snapped, truck towed to my shop, fixed)
July: 2016 ~128,131
*Road Force Wheel Balance performed
August: 2016 ~128,385
*Four wheel alignment
*New outer & inner tie rod, right
*New Tie Rod & Adjuster Sleeve
*New Front Brake Pads & Rotors
March: 2017 ~133,529
*New Right Rear Rotor, Caliper, and Pad
July: 2017 ~134,000
*New Water Pump
*New Thermostat & Thermostat Housing
*New T-Stat Gasket
*Flushed & Replaced Engine Coolant
*New LED Back-Up Lights
*New LED Fog Lights
January: 2018 ~141,288
*New DB8 Halo Projector Headlights
*New LED Blinkers
*Oil + filter, engine coolant topped
December: 2018
*New Harmonic Balancer
*New Trans Coolant Lines
May: 2019 ~157,000
*EVO 1/4 Pounder Stubby Front Bumper
*Fox 2.0 Shocks (10k miles) Rears
*Fixed Ground Wires
*Full Tune Up (New Spark Plugs/Coil)
*Trailer Wire Harness Installed
July: 2019 ~158,000
*Rigid Industry Dual Front Window Cubes Installed
*New Black OM Floor Mats
*New Skinny Fenders Installed
August: 2019 ~158,000
*New Badlands 12,000lbs Winch Installed
*Removed Spare & Tire Carrier, Back Bumper Removed.
November: 2019 ~159,340
*New radiator installed w/ new tunes
*Universal Joints replaced
December: 2019 ~160,000
*Upgraded Head Unit to an Alpine W650
*Radio Installed
May 2014:
December 2014:
January 2015:
February 2015:
March 2015:
May 2015:
June 2015: ~123,400
*New Back Brakes
August 2015:
Before:
During:
After:
June 2016: ~126,850
June: 2016 ~127,050
July: 2016 ~128,131
July: 2017 ~134,000
*New Water Pump
*New T-Stat Gasket
*New LED Fog Lights
*New LED Blinkers
December: 2018
May: 2019 ~157,000
*Fixed Ground Wires
July: 2019 ~158,000
