im pretty sure its
http://www.roughcountry.com/jeep_tj_2-spacer.html
right, so, are you thinking about adding this to what you have now or just replacing it with this new kit?
Adding it to my lift
Okay thanks well I was gonna do a 6 inch long arm and I knew for that I would have to do that work so I minus well just wait for it
Yeah ill have to up grade to a Dana 44 probably.. to much stress for the 35
I was told that before how much do you think I could get for my Dana 35 with a Riddlers diff. Cover and how hard would it to he to find something to match up
ok - 4.5" is A LOT of lift for a TJ and at bare minimum, you'll want to install a dropped pitman arm, track bar relocation bracket front and rear, install a slip yoke eliminator and cv drive shaft and in order to do that, you really need to have adjustable rear upper control arms. adjustable front uppers is highly recommended as well as they will help you to set your caster. again, this is bare minimum stuff but to do it right, you really should have adjustable control arms all the way around and perferably, long arms. with that much lift, you can clear 35" tires.
Eddie, you've been out of the tj game for a while.
On a 4" lift, you can use a drop pitman arm with a drop track bar bracket, good companies included a cross brace as well.
It's not the same drop bracket for a 4" and a 6" lift for a TJ. Running the wrong one will cause issues.
Of course it can get bump steer if the brackets don't match up to the coils.
wayoflife said:That's the way I remember it. Dropped pitman arm with track bar drop bracket. So long as you keep the draglink and track bar parallel, you're good to go. Ideally, you want them as parallel to your axle as well. Same is true on any other vechicle.
