Tire blocks?
Possibly spreading the sidewalls to set the bead on a wider rim? We've done that before but not used blocks all the way around. Just a thought.
is that to keep them from going flat? also to keep them from coming off the wheel if the bead breaks?
never seen that before
I googled it and found some brief info:
Allow you to run a lower tire pressure for added traction and better ride.
Allow you to ride with a punctured tire and get to a safe place to repair or a pit to change.
Doesn't disfigure or melt in stressful environments.
Won’t cause wheels to lose balance at high speeds, so no more harsh vibrations.
You could always save money and hit up Walmart instead
lol, i thought you were saying to get "slime" from walmart with that first pic..
^^This^^ Doubt they're running those blocks inside the tire with the wheel mounted. Sometimes when a new tire is shipped, it's squeezed flat from being stacked. Spreading the sidewalls apart makes it easier to seat up on a wheel. The tire is left like this for a while, the blocks are removed, and the tire mounted up. We've never used any kind of foam block or anything. Usually just use inner tubes in the same process.
My question is, if you took the time to stuff this tire just for this thread. If so I commend your dedication to this site. :thumbup::D
2014 JKUR
LMAO! I can't take credit...I found the pic a while back and stole it from the interwebs ;)
Yes they do. Google it.
