DanMojo82
I got the tramp stamp II from Poison Spyder and installed it today. I also installed the third brake light from Off Road Only that they sell as an add on for it. I thought I had it all figured out earlier today and gave myself a nice pat on the back, however, after driving around for a while and the sun going down, I can tell that its not quite right.
While just driving everything is fine, license plate light works fine, 3rd brake light works when the brake is pressed. However, the passenger side light where I spliced into either greatly dims or doesn't light up at all. Then when in reverse the passenger side lights down come on at all. What did I mess up on?
I have the green wire from the kit which is the tail/license plate light wired to the white wire with a purple stripe going to the tail light
I have the red wire from the kit which is the brake light wired to the white wire with a black stripe going to the tail light
I have the black wire from the kit which is the ground wired to the black wire going to the tail light
in park
brakes pressed
in reverse with brake on
My attempt at wiring
Any help would be greatly appreciated!!:beer:
in park
brakes pressed
