CrazyLarry
Whats going on guys got kind of a dumb question here but I failed jr high geometry so I need some help. After running my TF 2.5 coil lift for almost 3 years I am now noticing that my rear axle is offcenter about 3/4 of an inch towards the drivers side. So im looking to pull my drivers side tire in. As seen in the pic my rear trackbar is mounted on the lower hole. If I switch to the higher hole will that pull my drivers side axle in or make it worse with the tire sticking out even more? Im asking you guys before I switch mounting holes only to find out I made it worse. Thanks
