pastorwug
Anyone install the Synergy Sector Shaft Brace & Track bar brace?
After the carnage on Cadillac Hill this month (Professionaldriver) I was told about this and was wondering if it works as advertised.
Synergy says that it doesn't work with the OEM track bar and requires their track bar as well.
Ideas and opinions?
Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit
(1) PPM-8069-01 - Front Track Bar Brace
(1) PPM-8069-02 - Sector Shaft Brace
PPM-8069-01 - Front Track Bar Brace:
Bracket designed to distribute the increased load the track bar bracket encounters on a lifted Jeep
Added track bar bracket thickness prevents the track bar bolt from ovalizing out the stock mount
Bolt on fix for those who already have an ovalized track bar bracket bolt hole
Laser cut and CNC bent from 3/16" high strength steel
Grey powder coat finish for maximum corrosion resistance
Bolt on installation
Sector Shaft Brace:
Modular bracket designed to work in conjunction with PPM-8069-01 Front Track Bar Brace to eliminate drivers side frame flexing and sector shaft deflection.
Integrated bracket design adds strength to both the factory track bar bracket and factory steering box.
Grey powder coat finish for maximum corrosion resistance.
High quality grease able bearing
IMPORTANT: The PPM-8069 Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit is ONLY compatible with the 8075 Synergy Jeep JK Adjustable Front Track Bar. Synergy does not guarantee compatibility with any other track bar including the factory OEM trackbar.
:thinking:
Ideas and opinions?
Sector Shaft Brace:
:thinking:
