sway bars take out or leave in
jkfreak
I have sheared 3 bolts on the back sway bar should I take it out or put a grade 8 bolt in there, truck has a 3inch zone lift all the bump stop are in
Any info will help
Are you torquing the bolts to the right spec? Are they the right size? Both of those could lead to a broken/missing bolt.
How did the bolts shear out of curiosity?
I'm with you on this. I'm running a factory rear sway bar with my super big and heavy Pro Rock 60 rear axle supporting super big and heavy 40x15.50 Mud Grapplers mounted on super big and heavy ATX Slab wheels and all with 14" of vertical travel provided by my EVO Lever and still, I have never had a problem like this before. :idontknow:
You have a picture of your sway bar links? Are the threads inside or outside? Are the bolts shearing at the axle or at the bar? Some more info would be helpful. You said truck, is your vehicle a truck or a jeep?
When I went to replace my sway bar links on my 07 I snapped 3 of the 4. Ate you trying to extend / replace the links and its the stock ones stuck in?
