My ball joints are still the stock ones and I do know they need to be replaced I have a set of prosteers waiting to be installed. But the weird thing was this past weekend I left to go to Phoenix and I got back and this problem showed up, never had it before and it just started happening but I will check loose lugs I though that could be a possibility
Not saying that it's your ball joints for sure, could be your unit bearings are going bad on that side. That it just started happening is really how most failing parts go. One minute things are cool and the next, you're in need of replacing/fixing things![]()
I would check the track bar. Remember to torque both the bolt and the nut to 125lbs.
Already checked that and everything else torqued
