forum fun for everyone!!!!!!!
Ok guys i have been meaning to let everyone know how i made my amp steps work with taking the doors off. Its very simple to do even if your not a wiring expert. All you need is a ON-OFF-ON Switch, 16 ga. wiring, & connectors. Below is the steps needed to make this happen. Also is a simple pic of the wiring when complete.
Steps:
(1) cut the wire coming from the module about 6" away from door wiring harness (gives you room to strip)
(2) strip both ends of each wire to add more 16 ga. wire to them
(3) add wire to the power module wire and run to the middle of the rocker switch
(4) add wire to the wire coming from the door wiring harness and attach it to the bottom of the rocker switch
(5) make a new wire and attach it to the top of the rocker and then ground it to the body (theres to ground connections next to where you unplug the door wiring harness)
After wiring is done:
With the doors on flip the rocker switch to the down position. This will let the steps work when the door is opening and closing.
When you take the doors off flip the switch to the middle. That will keep the steps folded up.
When you flip the switch up it will make the steps fold down.
Steps:
