bkac
Snapped a body mount bolt lol
So I had a great idea to lift the body up a bit to weld in my EVO long arm brackets, it made it easier to weld across the top of them. I have taken out a lot of body mount bolts on JL/JTs the last few years and never any issues. Well that changed when I finally had one break on my rig. I ordered a new bolt so I figured I’d tackle replacing it. I found out the 2 bolts behind the front wheels have red locktite on them from the factory and the rest have blue. I have no idea why they did this. It’s recommended to heat the bolts with the red locktite before removing them.
I ended up jacking up the body high enough to pull the body mount out and noticed I had about 1/4” of the bolt showing. I decided to heat the bolt for about 10 minutes then used some pillars and it back right out. I was shocked and very happy at the same time. The entire job took less then 45 minutes to complete. I snapped a few photos along the way. I guess my reason to post is to warn others and share my fix. I felt the bolt get tight and tried to start working it easily back and forth and then snap! Mine was the the bolt right behind the front tire so every time I hit a bump I felt it under my feet. I couldn’t take it anymore.
Heating it with a propane torch
Once it was hot enough it backed right out with the pillars
And just like that, the broken bolt was extracted, lots of smiles and no drilling! Success
