MattAlpha
After having my forward axle's RK trackbar bracket rip off a few weeks ago I decided to replace it with the EVO front trackbar bracket. When I ordered it, I decided to buy the rear one too to make sure I didn't have a failure on the rear axle in the future.
I got some time today to get started on the replacement.
Here is the rear RK bracket beside the EVO bracket (being supported by the portion of the OEM rear bracket that I had to cut off).
The cut-down OEM mount. I had to do a lot of grinding with the angle grinder to remove the welds.
Cleaned-up (more grinding to get everything flush) and primed.
Top-coated
Mostly installed
Here's the snag...
I haven't sheared-off a bolt in a long time. I knew it was tight enough, but I wanted to get enough threads on both sides of the U-bolt so that I could install the locking nut on top of the that nut (as in the instruction's picture). I'm not a fan of left over hardware...yes I said I knew it was tight enough and still made a stupid mistake.
So I'll be off to the hardware store tomorrow morning to pick-up another U-bolt. After that one is on tight, then I'll weld the sides to the axle.
Top-coated
Mostly installed
Here's the snag...
