Removing Rubicon sway bar, what to do with the electrical wiring and plugs
geberhard
Douchebag
For those that have removed the electric Rubi sway bar, what have you done with the wiring? Not sure if it was posted here but remember seeing a couple stories about people having issues since the harness was tied on the front and exposed and water\mud cause havoc and Jeep went into limp mode.
Mine is tied over the sway bar skid hootchipappa "crossmember' on the front which I am chopping out.
Thanks!
Thanks, not planning to sell the sway bar yet (was debating a rear electric sway bar project, not sure if it is worth doing though :)).
The wiring is tucked up some, am trying to figure out a clean way to remove or re-route the setup, wish there was a junction disconnect somewhere under the engine bay, but I have not seen it yet. Yep, plan is to silicon up the connector ends.
Thanks!
I recently removed my electronic sway bar also, was wonder how you got the light to stop flashing on your dash
