recommended wheel offset
Patrfamilias
for a 2015 rubicon, with a 2.5" RK X-factor lift... with 35" tires on a 17" rim... is there a recommended backspacing? factory flares. in the market for rims, suggestions and reasons please.
use will be 95% on road, very little hard wheeling.
TIA, ciao
TIA, ciao
4.5" or less is what you want. If your running stock wheels and don't want to change them then you can get a set of 1.5" spidertrax spacer to obtain the proper clearance you need for the 35's
