Rear toe
Smp023
Just got back from the alignment shop and was told my rear toe is off. Drivers side is .55 degrees and passenger at negative .15. I have a 15 jku with an RE 3.5 coil lift. Running bfg 35 x 12.5. Any ideas on causes or solutions?
Correct me if I'm wrong, but rear toe on a solid axle vehicle is not adjustable. One of your flanges bent?
Make sure your wheels are bolted tightly to the hub with no excessive rust, etc on the hub. I guess you could have a bent wheel too. For kicks, you could do a tire rotation and then go get another alignment to see if there is any difference.
