Rear king air bump stop with evo double throwdown lever track bar bracket>
jeeper52
LOSER
Hi guys i was wanting to see if someone can post a pic of how you attach the air bump to the new evo track bar bracket? It appears to be setup for a stock bump stop. How does the king air bump attach??
The air bump bracket has to be welded into (frenched) into the frame where the OEM bump stop is located.
Set up the new frame side track bar bracket per the instructions, only tack weld at this time . Cut it off where it bends to the rear. Remove factory track bar bracket. Place the new EVO King bump stop bracket into place, trim to fit around new track bar bracket. Cycle the suspension to check clearance- fully weld once everything is set correctly. Then go fast...
Thanks Yeti. So i will end up cutting off the section of the new trackbar that holds the factory bump stop?
