Rear Driveshaft Question
Seahawkfan
Looking at my rear DS, the slip yoke (if that's what it's called) does not appear to be slipping in or out. Isn't it supposed to slide in and out during flex? Probably have about 4in lift with the EVO long arms. No sign of anything rubbing or hitting anywhere. Just thought I should see a little shinny steel on there once in a while.
Speedy_RCW
There’s very little movement because the driveshaft is pretty long. If you’re concerned pull the u bolts on the axle side yoke and make sure it moves.
Seahawkfan
Ok I figured if nothing was interfering or rubbing all was good. I'll check that out. Thanks for the straight answer. (This is for the other two.) I'm curious to see how much shaft I have in there already. :cool:
