Rear Dif Upgrade
jurko
I would like to upgrade my 2025 Wrangler 2 Door Sport rear Dana M220 with Detroit Truetrack LSD. Are there shops in Carson City/Reno area who would be able to do that for me? At the same time I would like to upgrade from 3.45 ratio to 4.10. What would be the cost of each upgrade?
Thanks.
Honestly, if you're going to spend the kind of money needed to upgrade anything in your rear axle, I would HIGHLY recommend you install a selectable locker like an ARB or e-locker. Being that you're in Carson City, this is especially helpful to have when it snows and or the roads are icy as you can leave your rear end open and lock it as needed on the trail. Being that you're wanting to upgrade your gear ratio, I would put the TrueTrac in your front axle as you're going to have to pay for labor regardless and so long as they're opening things up, that would be the time to do it.
Regarding shops, there's a reason why I make the drive down to Hanford, CA and have Disciple Offroad do the work - they are that good. That said, the only other shop I might recommend is Driveline & Gear in Sparks.
Oh man, thanks for your very helpful advice. Appreciated.
I subscribed to your YT channel and watched many of your videos and if I remember correctly you had re-gear done at Disciple Offroad ? And spoke highly of them.
I checked it on map and it's about 5 hours drive. Did they do it in one day or did you you stay overnight?
Thanks again.
